cold air intake questions. PLEASE HELP!!!!!!!!!!!!!!!!!!!
Old Aug 23, 2011 | 01:04 AM
go88iroc's Avatar
Car: 1988 iroc-z red 5.0 tpi
ok for a while ive been wanting to put a cold air intake on my 88 iroc and i just dont know where to start like can any one PLEASE help me and like tell me where i can find like a kit i can buy. and oh one more question what do i do with the Mass Air Flow sensor connector cause i know if u leave that unplugged you have a rough start or well i did. is there cold air intakes that come with a MAF sensor connector hook up. id someone PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 23, 2011 | 01:19 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: cold air intake questions. PLEASE HELP!!!!!!!!!!!!!!!!!!!
if you see i put a 3" pvc pipe in as intake piping then put the maf sensor pipe in at the end then put a spectra air filter directly on the other end of the maf this will breath better then the after markewt ones that are only 2-2.5 inch piping
Old Aug 23, 2011 | 01:20 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Your car should already have a cold air intake.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
