Exhaust manifolds glowing red.....
Old Aug 24, 2011 | 01:48 AM
Goldenbullet44's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 smallblock aftermarket cam
Transmission: Borg warner T-5
my cousin has a 1987 z28 camaro with the 350 tpi in it. Well it runs doggy and has no power at all, it also overheats really badly. We replaced the water pump radiator spark plugs wire cap rotor took it out for a spin well it didn't have power what so ever.... We pulled over popped the hood and the exhaust manifolds were glowing cherry red we called up my friend to come tow it decided driving it at that point in time was not an option unless we wanted to make things worse then they already are...
What would you guys think the problem is with this car?
We are thinking about taking the heads off replacing the head gaskets check the pistons and stuff make sure we didn't mess anything up, thinking about converting it to carburetor...
Old Aug 24, 2011 | 08:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Exhaust manifolds glowing red.....
Spark advance is wrong. Check the timing with the EST/BYPASS connector open, should be at 6* BTDC.
SES light work? Is it on? If so check the codes.
RBob.
Old Aug 24, 2011 | 08:23 AM
Yup, timing is WAY WAY WAY retarded...
Just crank the distributor body CCW about 20° and see if it's any better. That won't make the timing "right", of course; but will tell you QUICK if that's the right path to go down.
Old Aug 24, 2011 | 06:42 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
thats timing man
Old Aug 25, 2011 | 08:22 PM
Damon's Avatar
Or the converter is plugged up. That can cause a glowing exhaust and no power, too.
Old Aug 26, 2011 | 11:55 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Exhaust leak particularly near the header(s) can also cause it.
Old Aug 27, 2011 | 02:14 AM
Al Weyman's Avatar
Car: 87 Iroc Race car, 71 Z/28 Race car
Engine: 5700cc self built
Transmission: Muncie 4 speeds
Axle/Gears: 3.75/3.5
I have seen valve timing out also cause that but most likely ignition timing too far retarded as others have said.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
