Block-off EGR
Old Aug 25, 2011 | 09:15 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
Block-off EGR
Did anyone here get rid of their EGR valve? What are the benefits/drawbacks of doing it?
Old Aug 25, 2011 | 12:00 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Block-off EGR
I had a modded TPI with EGR, then a StealthRam without EGR, then the StealthRam with EGR. I noticed no (EGR related) difference in drivability or performance in either configuration. I would keep the EGR valve / system intact and operational.
Bill
Old Aug 27, 2011 | 12:12 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Block-off EGR
Exhaust gas is inert that is it provides no fuel, or oxygen for combustion, but displaces a small volume otherwise available for air/fuel, less fuel consumption, but only during part throttle (cruising.) I see no reason for disabling it as it isn't active in WOT. When you race your car you're either idling, or in WOT so the EGR is a moot point in which case it's up to you whether to block it or not.
Old Aug 27, 2011 | 09:03 AM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
Re: Block-off EGR
thanks guys for the reply! i was just wandering because my idle is funky and chances are at 160K miles my egr valve needs cleaning/replacing. thanks again!
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
