bent tpi runners please help ( not dented just bent slightly )
Old Sep 14, 2011 | 12:11 PM
freshZ28's Avatar
Hello , my motor was bolted to a engine stand when it fell over . When the engine hit the floor it rolled over on its side and slightly pushed in one of the runners . When I went to to put the plenum on to check if the runners were in fact bent , the plenum would not line up . Has this happened to anyone and is there a way to bend the runner back into place ? Mind you to the naked eye there appears to be no damage until you try and bolt on the plenum , so not much damage was endured . I also thought of slightly heating the runner and bending it back to its original position but I don't trust the idea . Thanks in advance for any help .
Old Sep 16, 2011 | 09:20 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: bent tpi runners please help ( not dented just bent slightly )
Too bad about your engine falling over. Could have been worse though.
Maybe, if you loosely bolt everything together, then slowly tighten the bolts down, it would slowly pull everything into alignment. I expect this procedure would add alot of stress on the plenum and runners, but it might go back together.
Hope this helps.
Old Sep 17, 2011 | 12:33 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
You could try bolting them down and then heating them. But if you need a new set pm me.
Old Oct 3, 2011 | 09:38 AM
freshZ28's Avatar
Hope this helps.
Thanks for your suggestion but the bolt holes are to far off for that procedure . I am not sure if I replied correctly to your suggestion . I am new to the whole forums thing . I clicked on quote because when I click on reply it does not tell me if I am replying to you or the other reply that I received .
stalkier
Dec 6, 2015 11:25 PM
Cameeeero
Sep 18, 2015 04:00 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
