ecm - injectors
Old Sep 23, 2011 | 10:31 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
ecm - injectors
i have a camaro with a 305 tpi all stock but it has a chip for a 350 in it would this make the car run lean or rich
Old Sep 29, 2011 | 12:50 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: ecm - injectors
A 350 chip in a 305 will be rich.
Old Sep 29, 2011 | 07:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ecm - injectors
If this is the '89 the engine will end up running lean. The BLM will increase to add additional fuel.
The reason that it will be lean is that the injector flow constant in the calibration is higher. The ECM will calculate a smaller PW for the given airflow (from the MAF).
Of course this is assuming that the stock 19 #/hr injectors are still being used.
RBob.
skeltor
Feb 2, 2016 10:37 AM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
