Fuel pressure issue? Remove Cold Start??
Old Sep 27, 2011 | 06:09 PM
oracle646's Avatar
So I have had problems with my 85 TPI starting. Around 2 weeks ago I would have to crank it and crank it and eventually it would start then after about 10min it would run fine. I replaced the fuel filter, fuel regulator and now I have I think 25pound of pressure and it won't even start at all.
I heard someone mention removing cold start or a cold start kit to help solve this? Or is it an injector possibly?
Thanks a ton peeps! A ton!
Tyler
Old Sep 27, 2011 | 07:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel pressure issue? Remove Cold Start??
Low pressure is not helping.Need to determine where you are losing pressure
Need to determine where pressure is bleeding off.
Disconnect and cap the line to the CSI and see if your pressure comes back
If you didn't have the pressure problem , you would need to 1st determine if engine rich or lean on cold crank.
If the CSI is not working engine would be lean and if the CSI was leaking engine would be too rich
Old Sep 28, 2011 | 05:57 PM
oracle646's Avatar
Why does everyone eliminate the Cold Start Injector?
Old Sep 29, 2011 | 11:25 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Over time, they tend to go bad. They either stick open, flooding your engine with gas, or they stick closed- not working at all. I do not think they are available as replacements, and even having them rebuilt is problematic. Using a Cold Start Block off kit from Ebay, and a tune from a later year where cold start was eliminated by the factory solves the problem. These tunes use all 8 injectors to "richen" up the mixture for cold start.
Old Sep 29, 2011 | 04:22 PM
oracle646's Avatar
so as may have read I am having problems with my car starting, could it be cold start and should I just remove it?
Old Sep 29, 2011 | 10:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I noted work out why you have low fuel pressure 1st.
Pump may be on it's way out
The injectors may be leaking
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
