8.8 1/8th track whit drag radials
Old Oct 6, 2011 | 04:51 PM
1roc89z28's Avatar
how much should i hit whit regular street tires.? since gripping is going to be hard
Old Oct 6, 2011 | 07:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 8.8 1/8th track whit drag radials
whats the combination? What was the 60 ft on drag radials? What street tires will you run?
How well can you pedal the throttle? lol lots of variables here that can change your ET's
Old Oct 7, 2011 | 02:37 AM
1roc89z28's Avatar
1.985 its my avarage 60 ft...im just running no brand regular tires.
Old Oct 7, 2011 | 08:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
hmmm if with drag radialsyou can only get a 1.985 then street tires are gonna be alittle worse, but most guys can cut a 1.98 on street tires with little effort.
Assume you go to a 2.1 60 ft on street tires you'll probably drop down from 8.8 to near 9.0
Old Oct 7, 2011 | 12:10 PM
1roc89z28's Avatar
oh ok. i will aim for the same 60 ft then. 9.0 not bad. thx ill let u know what i hit.
Old Oct 7, 2011 | 10:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Does the car have any gear upgrades? Is it a manual or automatic? If auto, does it have a converter?
If no converter and with stock gearing, it may not need drag radials to run good and should run same times on street tires as it does radials.
Old Oct 8, 2011 | 04:06 PM
1roc89z28's Avatar
stock gears. 3.23 gears. its a 91 l98. stock torque converter...
Old Oct 8, 2011 | 04:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
On stock converter I dont see you gaining much at all with drag radials, you should beable to nearly match those 60 foots on street tires if they are a good soft street tire.
Old Oct 8, 2011 | 08:48 PM
1roc89z28's Avatar
well i hope so. to bad i got different brands on the back. realy low budget
Old Oct 8, 2011 | 11:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
See what you can do, then look at getting a converter. Makes a huge difference and will work well with the drag radials
Old Oct 9, 2011 | 02:22 PM
1roc89z28's Avatar
. what kind of converter? ill let u know how it goes. its till thursday track days
Old Oct 9, 2011 | 08:48 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
ive got an 89 iroc with a 353 tpi and i ran it on the track friday night at test and tune and it went here is the time slip reaction was a .619 1.964@60ft 5.811@330ft 8.486@594ft 9.084@1/8mile mph was a 75.35 but i have a real hard time hookin up tho good luck on your run
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
JSDaddy189
Sep 26, 2015 03:50 PM
