need an answer
Old Oct 12, 2011 | 09:21 PM
esp68camaro's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
need an answer
hey guys I bought a 86 iroc 305tpi auto in may ive worked on it replacing everything all sensors and it stays in limp mode...I decided to take the tpi off and put a carb on it, when i took off the tpi I started looking threw the wires and noticed the oil sending unit had 2 plugs a small one thats on top off the sending unit and a big one on the bottom, the bottom was unplugged and stuffed behind the wiper motor. Could this be my problem of it goin in limp mode?
Old Oct 13, 2011 | 01:15 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: need an answer
How do you know its going in limp home mode
Old Oct 13, 2011 | 06:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need an answer
No
the unplugged unit is the back switch to run the fuel pump if fuel pump relay fails
Old Oct 13, 2011 | 06:50 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: need an answer
i thought that was supposed to cut power off to the fuelpump if the oil pressure got too low?
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
