TPI Cold air intake, anyone built one?
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I'm really wanting to get rid of the factory air box on my 89 IROC, it just looks restrictive. Has anyone bought or built a cold air setup for their's? If so have you noticed a difference?
And post some pics if you don't mind..
Here's my stocker...
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: TPI Cold air intake, anyone built one?
ive heard of people doing the c4 tpi intake setup havent actually seen it on a third gen but if u wanna sell that air intake setup ill def look into taking it off ur hands im planning on going back to tpi on my 89 gta
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Cut the filter bottoms out and run dryer ducting from the filter to the fog light/grille area to make a sort of ram air....or better yet fab a plastic or metal box to really make it a sturdy ram air setup.
Its less restrictive than you think....that setup will support 500 hp 11 second motors. I made a switch to a home built 3.5" CAI and didnt see much if any gain on a mid 11 second motor
Car: 1990 IrocZ Convertible
Engine: TPI 305 (factory & anemic)
Axle/Gears: Crappy factory 2.73
Back in the day Hawks used to sell a couple of them , but they have since been discontinued. I agree with Orr89RocZ. The one's I saw being offered were nothing more than something you could build yourself. I know years ago I removed my high beam bulbs and ran ducting to the back of them and attached it to the core support. I then installed blackouts (all black car) with a single 4 inch hole drilled in each one in front of the high beam location. Didn't look too bad, after all it was a race car.
Car: 89 IROC-Z
Engine: 355ci SBC
I don't mind running the stock air box, the only issue is mine is cracked. If you see the pic up there you will notice it. And Hawks third gen wants $250.00 for a used one.. what the hell ever! Thats rediculous... so... either I'm going to try to fiberglass mine and fix it or find another one. Just didn't know if it was worth doing or not. Since it flows enough air I'll keep it stock looking, although I'm building a forged 355ci with a nice set of heads to install in front of a T-56.
If you don't wanna go through the hell of glassing the cracks up you might consider checking your local wrecking yards. I've seen good ones around here, and I bet you could get one cheaper than the materials you would need to buy to fix yours up.
Car: '88 Trans Am GTA
Engine: 4++,350 & 305 CIs
Engine: LR4 4.8
i have a cowl hood so there wouldnt be much trimming of my hood i would have to do i just like the set up better then the firebird tpi air snorkel sucks up hot engine air while the camaro iroc sucks up nice cold air from the front of the air damn
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
