No crank, no fuel prime after complete build.
Old Oct 29, 2011 | 09:00 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well I've finally finished putting the car back together after a 9 month teardown.
Anyways I put a different steering column switched tumblers.
the car was an auto is now a stick shift. jumped the safety neutral just to make sure. still no crank.
I put a trigger on the starter and it cranks.
all the lights come on, all the ground are hooked up.
where should I start? what should I start doing to diagnose this.
also I have the vats deleted in the computer but the previous owner had put a resister in the wire to eliminate it. well while crawling around under the dash that resistor broke off. so the connector is just sitting there?
Old Oct 29, 2011 | 10:49 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: No crank, no fuel prime after complete build.
that seems like a really good place to start.....
I'm sure someone will chime in here, but I would think the resistor is no longer required.. But a connection would be...
Old Oct 30, 2011 | 02:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
still no crank.
I have the vats deleted in the computer ?
VATS reprogrammed in the computer only gives you fuel part of VATS ;
you still have to bypass the starter enable relay for VATS to be fully deleted
the previous owner had put a resister in the wire to eliminate it.....that resistor broke off.
Maybe the VATS module was still working ( on the starter component ) and dropping the bypass resistor out has taken out the still being used enable relay?
( if you didn't bypass the relay when you had the delete chip burnt )
Old Oct 30, 2011 | 10:28 AM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
hey I'm not sure how to use the diagram to bypass the disable relay?
Old Oct 30, 2011 | 07:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/tpi/...ay-bypass.html
Glowsock
Jul 24, 2025 03:15 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
