Best upgrade for a 91 model L98 TPI
Old Nov 1, 2011 | 03:20 PM
PetursGTA's Avatar
Hello guys/girls.
What are the best performance upgrades for a L98. Already have the stock exhaust removed and fitted it with Hooker headers and Flowmaster exhaust.
It's installed in my 1988 Firebird GTA. Want it to move a little
Does it make a difference to go from stock 1.5 rockers to 1.6 roller rockers?
Regards, Peter.
Old Nov 1, 2011 | 06:44 PM
PetursGTA's Avatar
Re: Best upgrade for a 91 model L98 TPI
Ok, I'll clarify..
Looking for the best aftermarkert Hi-flow intake manifold and runners...
Any suggestions?
Old Nov 4, 2011 | 09:57 PM
PetursGTA's Avatar
Wow, and the crowd goes wild (sarcasm)
Nobody willing to give a Newbie GTA owner advice?
Old Nov 4, 2011 | 10:24 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Not getting any love from thirdgen I see. Wish I could recommend some for you but I only know about exotics and LS engines as far as modifications. I am new to thirdgen myself as I just bought a 1989 GTA. Dig through the forums on here and GTAsourcepage and there are a lot of recommendations out there.
Old Nov 4, 2011 | 10:41 PM
PetursGTA's Avatar
Thanks for replying. I really appreciate it
I'll keep on going through posts and info.
Just want the best for my rustfree GTA
Old Nov 4, 2011 | 11:15 PM
Drew's Avatar
You're not getting a lot of replies because:
a) every part you could think of has probably already been discussed if you don't mind using the search feature to dig a bit.
b) none of the currently available bolt-on parts are going to do as much as the headers and exhaust you already installed.
Unfortunately when dealing with TPI, short of replacing everything, you're just changing one or two parts of a well balanced system. Those one or two parts aren't going to do much when everything else is still optimized for the old run characteristic. That's my anyway... You could do roller rockers (may or may not bolt on without mods) or a cam (see previous disclaimer), or large tube runners, or a base, etc and it's probably not going to do much. A big cam and high flowing heads are going to be stifled by the stock intake... So where do you turn for a good return on your investment?
Nitrous oxide. PS, nitrous + TPI torque = some pretty crazy burnouts. Without traction mods it's probably not going to be all that effective.
Old Nov 4, 2011 | 11:24 PM
Guest
Guest
Posts: n/a
What? On 150 shot on the street plus broke posi I never spun wounce....
-nitrous over 3000 rpms
Old Nov 5, 2011 | 04:32 PM
Drew's Avatar
Yeah, I don't know man... I have enough traction problems on dry pavement without the nitrous... so... yeah.
Old Nov 5, 2011 | 09:18 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I'd say fuel pressure regulator, I got the holley version, going on 11 years with no problem, then again, I put 500 miles a year on the car.
Old Nov 6, 2011 | 08:01 PM
Guest
Guest
Posts: n/a
Crap tires?????
Old Nov 7, 2011 | 12:57 PM
Drew's Avatar
Crap tires?????
Not even close... 2 year old Comp T/As with maybe 3k miles on them. Maybe instead of trying to figure out why my tires spin, we should be trying to figure out why yours don't?
Something has to be wrong if you're talking about a 150hp shot, on a healthy L98, getting traction on one wheel peel. That recipe should be good for spinning through 4th gear...
Old Nov 7, 2011 | 01:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Drew I've been holding this lil jab but can't hold it anymore..
You must be running Gatorbacks because every other tire has waaaaay better traction and wouldn't spin like that!!!!! lmao
Old Nov 7, 2011 | 01:27 PM
Drew's Avatar
I wish I'd had the forethought to go back and photo the burnouts from the first couple weeks while it still had Goodyear tires... They were blocks long and hilarious.
I've always had traction issues with my Formula, but only when really trying. Under normal driving conditions the Goodyear tires were absolutely the worst. Even still, with good tires, burned rubber seems to follow the car like a shadow.
I've had plenty of sticky tires on the car... But Goodyears were the worst
Old Nov 7, 2011 | 02:09 PM
TTOP350's Avatar
stock car with stock 1986 IROC wheels and org gatorback tires.. O if I would have kept them!!
this is just some of the stupid stuff we used to do back in the early 90s!!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Nov 7, 2011 | 05:46 PM
Drew's Avatar
I wish you lived close....Id beat the the dog **** out of you....
Easy Killer... Be careful what you post... http://www.internetbrands.com/ib/ter...e=thirdgen.org
the following behaviors are strictly prohibited:
Harassing, intimidating, stalking or threatening other community members
FWIW, 89-92 L98s are markedly faster then earlier MAF L98s. That's why they're typically 5/10ths to a full second faster in the 1/4 mile. If my L98 87 Iroc went up against my L98 91 Formula, it would get stomped like it was tied to a tree. That's with two equally optioned cars even. Take an 88 L98 with single cat and 2.77 gears and it'd be even worse.
Old Nov 8, 2011 | 02:23 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Best upgrade for a L98? Ditch the TPI. Get a good exhaust. Upgrade the heads and a cam that fits your driving preferences. Then follow it up with Gears and a tranny beef up with a converter. I am not gonna name parts since everyone is not the same. Some want a quick light to light car and others want a fast 1/4 car. Find out what others have done for their goals which are similar to yours and look into what they went with.
I personally like doing the suspension first then bolt ons then seeing if its worth it even putting time into a L98 for what your goals are.
Like others have said this has been talked over and over again. Search for threads.
Old Nov 8, 2011 | 11:55 AM
TTOP350's Avatar
My god kids, Don't make me stop this freakin car and get my belt out....
Old Nov 8, 2011 | 02:28 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
patinz88 i do agree that alot of your posts do seem immature.... your profile says 40 aka 25..but alot of times you act 13... this is a mature site and many people love being on here..... just chill out and have some more sense in your post..... it really does make you look like your some preteen seriously which isnt cute at all.....
Old Nov 8, 2011 | 02:53 PM
Drew's Avatar
I love this thread.
This thread is now a burn out pic thread... Since the OP is long gone, and the question can be answered by searching, and so on.
Did I mention my 87 Iroc is slow? This was a 45 second brake stand, compared to the pics I posted earlier of just rolling into the throttle in my Formula.
"Do you want to get in the car, so we can get the hell out of here before the cops show up?"
Old Nov 8, 2011 | 03:04 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Best upgrade. Heads, Cam, Intake. Same applies to most cars.
Old Nov 28, 2011 | 07:07 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
this is that guy xflgkingpin with the car he called rocky. He made several topics about getting pulled over for "dwb". Got banned a couple times. Funny thing is he wrecked his car breaking traction on the freeway. Believe they used the jaws of life to remove him from the poor iroc. There is a happy ending to this story however. He did bring rocky back to life and continues to grace the tech boards that is TGO with his presence.
Rock on, Pat.
Old Nov 28, 2011 | 07:34 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Why is that in this thread?
Old Nov 28, 2011 | 07:40 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Because people like patin88z aka xflgkingpin are the cancer that is killing tgo lately. Are the mods asleep or what?
Old Nov 28, 2011 | 07:50 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Lol, Ahh...had no idea that was the same guy.
Old Nov 28, 2011 | 07:56 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
No us mods are not asleep, we have lives outside thirdgen.org that causes us not to be online 24 hours a day 7 days a week, however since this thread has gone downhill rapidly it will be closed.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
