How do you install the fuel rail and injector assm.?
Old Nov 2, 2011 | 10:14 AM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
I tore my intake all the way down to paint in 3 months ago and now I can't figure out how to get the little tubes on each end of the fuel rails in. Since the injectors go in at an angle I can't assemble it before putting them in. Any help would be great.
Old Nov 2, 2011 | 11:31 AM
Twin_Turbo's Avatar
Re: How do you install the fuel rail and injector assm.?
Yes you can assembly it all, use the clisp to hold the injectors, then assemble the 2 halves and push in one bank of injectors partially to "start" them in the hole, then carefully persuade the other side to go down the hole. Smear some o ring lube on all the o rings before install.
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
