TPI INTAKE GASKET
Car: 92' Formula T-Top
Engine: L98 With Custom CAI
Transmission: BUILT 700R4 with B&M Mods
TPI INTAKE GASKET
Hi, im wondering the easiest way to change the intake gaskets on my 92 formula l98?
What do i need to take apart and not need to take apart ect... Do i really have to take all the runners off ect or will it all unbolt and stay in place with the intake ect
-Danny
-Danny
Engine: 4++,350 & 305 CIs
Re: TPI INTAKE GASKET
Yes you have to remove a lot of things.. its not hard but does take some time.
The best way to learn is to do it.
Buy a factory service manual and learn to use it correctly!
I've done this more times than I care to admit, and I'm going of memory here. DISCONNECT THE BATTERY!!!! I would remove the alternator, but not needed. Plenum, Runners and distributer need to come out. You can leave the fuel rail on the intake and just unbolt the rail from front of the block (if the bolt is still there) as well as the fuel supply/return connections by the intake. Be carefull of the small o-rings on the fuel lines. This will allow access to the Torx bolts that hold on the manifold. There is no magical easy way to do this, just get in there and do it. A word of caution, if you haven't done this before... Read up in this forum on removing and re-installing a distributer. Tons of info and you may need it. And PLEASE DISCONNECT THE BATTERY!!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
