LT1 injectors on 89 TPI?
Old Nov 3, 2011 | 09:12 AM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
I have discovered I have a leaky injector when I was deleting vats. I want to take care of it before it washes the rings out and gets in the oil cuz who knows how long the previous owners drove it like that. My question is can I run LT1 injectors without having to modify anything. I figured the injector bodies should be the same so mounting them in place shouldn't be a problem but are the injector plugs different? Also what's the flow rates on stock TPI injectors cuz the ones I want to get from a guy in the forsale section are 26 lb.
Old Nov 3, 2011 | 06:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: LT1 injectors on 89 TPI?
L98's and 92/93 LT1 are 22lb
94'+ LT1 are 24lb
All interchange but I don't think you can step up to 26's on a L98 without a retune
Old Nov 3, 2011 | 06:32 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
They will physically drop in. They are slightly shorter but not enough to make a difference. The connectors are the same.
You will need to tune a chip for the car with the new injectors. You can drive it with the stock chip but it will run pig rich and thus be down on power.
Old Nov 3, 2011 | 10:15 PM
adam.binkley's Avatar
are LS1 injectors much different from TPI injectors? other then the wiring pigtail will they interchange?
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Steve78LT
Feb 24, 2016 12:15 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
