TBI TO TPI CONVERSION
Old Dec 11, 2011 | 11:58 AM
  #51
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
Re: TBI TO TPI CONVERSION
thanks for the downloads now while my back is healing i can research
Old Aug 21, 2012 | 01:21 AM
  #52
haisud's Avatar
Can you re upload some pictures? they dont work
Old Dec 6, 2021 | 08:33 PM
  #53
jpetritsch25's Avatar
Car: 92 camaro
Engine: 5.0L TBI
Trying to resume this forum as I am now doing this conversion. I have a 92 RS, got a TPI system out of a 90iroc. Everything is installed. However the car won’t start. No crank and no interior lights. Any help is appreciated for those that still remember?
Old Dec 6, 2021 | 08:54 PM
  #54
Car: 92 camaro
Engine: 5.0L TBI
I would like to mention it was noticed that the dash harness is a little different. It plugs into the ecm but a few wire colors don’t match.
Old Dec 7, 2021 | 09:30 AM
  #55
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Going from TBI to TPI, I would expect the ECU (at least the prom) and the wiring harness to be different.
I have some info on my website. https://sites.google.com/site/darbys...tpi-conversion The TPI handbook has the pin-outs for the ECM. I also have a wiring spreadsheet there that shows the pin-outs of the C205 connector from the instrument panel to the ECM. Could be an issue there too.
Lastly, VATS would likely need to be disabled in the TPI Prom. Needed to do this for my installation. Not sure about yours, since your TBI might have had VATS too, but even so I would suspect difficulties, since that was the theft control of the day.
Old Dec 7, 2021 | 03:47 PM
  #56
aliceempire's Avatar
Transmission: T-5, TH350, T-5
I did nearly the exact swap you're doing but on the Pontiac side. I swapped a 90 gta tpi into a 92 base firebird. Interior lights and not crank shouldn't have anything to do with the swap. All those pins are in the same place. I think you have a fuseable link or something not hooked up. http://www.austinthirdgen.org/index.php?pid=19 at the bottom of the page are the c100 connector pinouts.
The vats from the 92 should still be operational if it was on the tbi. Nothing to change iirc.
The speedo uses a buffer box on the tbi so you need to bypass that and go straight through the ecm for that.
Old Apr 18, 2022 | 10:03 PM
  #57
Car: 92 camaro
Engine: 5.0L TBI
Thank you all for the support. The car is up and running. We did not bypasss the buffer box yet so I still don’t have a Speedo. We also did have issues with the VATS system. A lot of hiccups in the process but finally am there. Thank you again.
Old Apr 18, 2022 | 10:12 PM
  #58
Car: 92 camaro
Engine: 5.0L TBI
One quick question, where is that VSB or buffer box located?
Old Apr 19, 2022 | 11:28 AM
  #59
It's a bright yellow box near the ecm. Wires from that harness need to go directly over to it.
Old Apr 30, 2022 | 02:50 PM
  #60
Car: 92 camaro
Engine: 5.0L TBI
Moved gray wire from D to K. Also someone wrote to crest a u from C to F. Are we doubling up on wires. Speedo and odometer are currently not working
Old May 1, 2022 | 12:53 PM
  #61
Car: 92 camaro
Engine: 5.0L TBI
Mine is clear? Is this what I’m looking for. Might be the reason I had a hard time finding it
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
