TPI Throttle body gaskets
Car: 91 Z28
Axle/Gears: Stock
Hawks, Napa, and Orielly have different versions of gaskets for a 91 TPI throttle body. I'm removing, cleaning, and re-installing the throttle body(IAC as well) on my TPI and am curious as to how many gaskets I would need to replace. A pic of the Hawks kit is below and this is different than the Napa kit that includes the main throttle body gasket and the runners. One of those is obvious, the other aren't. Yes, I could take it apart first and find out, but it'd be nice to have the replacement gaskets on hand. TIA.
Engine: 4++,350 & 305 CIs
Re: TPI Throttle body gaskets
The gaskets you have pictured are the ones you need if you take your Tbody off and apart.
the kit for with the runner gaskets are if you remove the(suprise) plenum,runners and intake.
It takes maybe 10mins to remove your Tbody. Heck you could pop the hood and see where these gaskets go.
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
The one to the left of the main TB gasket is the gasket for the top plate that screws to the top of your TB. Not sure what the other one is for though.
Car: 91 Camaro RS
Engine: 305 TPI conversion.
the other two are for the casing below the tb and the sensor that screws into the side of it.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
