TPI 85 IROC 305
Old Nov 19, 2011 | 10:47 AM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
TPI 85 IROC 305
I'm replacing the original injectors on my 85 305 TPI. I want to change the CAM and lifters too. Looking for a moderate change on the CAM. What suggestions would anyone have for a replacement cam and lifters? With the increase in cam size, should I increase from from the stock injectors?
All input is welcomed! Thanks
Old Nov 20, 2011 | 09:38 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: TPI 85 IROC 305
I upgraded my motor with a Comp Cams XR264HR cam and matching valve-train components. I used their Camquest program and talked with a tech rep for help. Upgraded my injectors to 24lb Bosch III's. Went to Southbay Fuel Injectors for the help on those. My car is a 350 TPI, but this should give you a ballpark idea. I am sure you'll want to upgrade injectors, so I'd give them a call. They are very helpful and know their stuff.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Derick15
Sep 17, 2016 05:28 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
