AFPR pressure
Old Nov 21, 2011 | 04:27 PM
86_iroc's Avatar
AFPR pressure
So I'm getting ready to finally get a custom prom and I figured I should go ahead and put an AFPR on it before I ordered it. The problem is I don't know what would be the best pressure for my application. I have an 86 IROC with a 305 TPI. It has a lot of mods such as 1 5/8" long tube headers, 3" pipe into a flowmaster 80 series, descreened MAF sensor, throttle body spacer, air foil, ported plenum, 1.6 ratio roller rocker arms, Comp cams XE256H hydraulic flat tappet cam(Specs: http://www.compcams.com/Company/CC/c...x?csid=84&sb=2), new springs and timing chain, Hypertech distributor cap, and a few other small things.
So if anyone can give me any idea that would be awesome!! Also, what temp thermostat would you recommend?
Old Nov 21, 2011 | 04:32 PM
86_iroc's Avatar
Re: AFPR pressure
Here's a pic just for fun
Old Nov 21, 2011 | 04:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: AFPR pressure
yes, do a $6e .bin and get rid of the 9th injector.
Old Nov 21, 2011 | 05:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: AFPR pressure
A lot of peeps say you have to run 43.5 on the money or your bumpers will fall off, spare air will get hot and the blinker fluid will squirt in your eyes while driving.
I run 48-51psi.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Stryker412
Sep 20, 2015 06:59 PM
alpine247
Sep 16, 2015 05:25 PM
TBRays98
Sep 6, 2015 05:05 PM
355tpipickup
Sep 4, 2015 05:32 PM
