86 TPI hose routing question with pics
Old Dec 8, 2011 | 04:52 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Ok guys I have a question.. 86 Trans Am with TPI setup.. I have a hard line that is T-ed into the vacuum hose that routes out the back of the plenum and goes to the cruise control servo. I was wondering where does the other end of this hard line find its home? Here is the line at at its 3 way T..
Here is the line goin across firewall of engine bay.....
Here is the line going thru a loom and wrapping downward....
Here is the line with no home. Please help me find a home... or let me know that its ok to remove this line all together and cap it at the T fitting. Thank you in advance!
Old Dec 8, 2011 | 05:59 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Re: 86 TPI hose routing question with pics
I have the same lines on mine cut and capped with no problems, no cruise control either. idk where it ends up its been cut like that since i bought the car so cant help ya there.
Old Dec 8, 2011 | 09:26 PM
Copchaser's Avatar
Yeah Tim, I've never noticed mine like that either til today. Although it didnt effect my last build, I was just curious. Guess ill be capping that off this weekend. Thanks big homie.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
lakeffect2
Aug 23, 2015 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
