different afpr
Old Dec 17, 2011 | 01:07 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
different afpr
hey guys i need another afpr similar to the aeromotive 13301 unit for my FIRST TPI intake.... mines is leaking through the vac port and i dont want to deal with this brand anymore.....
Old Dec 17, 2011 | 07:44 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: different afpr
I've have a Holley 512-501 going on 10 years.
Old Dec 17, 2011 | 07:55 PM
88fastgta's Avatar
Re: different afpr
thanks but i need a universal unit that will fit with any engine type.. that one is only for the stock tpi type....
Old Dec 17, 2011 | 08:00 PM
88fastgta's Avatar
Re: different afpr
what do you guys think of this
http://www.summitracing.com/parts/ACC-74567/
Old Dec 17, 2011 | 08:04 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: different afpr
I see that one is not rebuildable either.
Old Dec 17, 2011 | 08:10 PM
88fastgta's Avatar
Re: different afpr
yea i know.. but im not worried about that... usually for a part like that i'd rather get a whole new unit anyways considering that they aren't too expensive.... i just dont want my aeromotive unit because sometimes it leaks fuel in the vac port and other times it doesnt..... plus is big and clunky and i dont really care for the design of it..
Old Dec 17, 2011 | 10:53 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: different afpr
In case you don't find anything to your liking. The Holley I have is modified to avoid cutting into the plenum some say because the adjustment **** is too large and since I can't leave well enough alone I replaced the supply & return with 3/8" SS tubing and Swagelok fittings to make the connections all the way to the tank using SS braided fuel hose where needed. I really don't like it under the plenum and plan to move it off engine. which would just require threading the regulator inlet ports. and replace it with a front cross pipe and install a Tee in the middle.
May not be what your looking for, it can be rebuilt, Just a thought, it is a good unit and aesthetically pleasing.
Here's a picture of it modified for vertical orientation.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
