87 IROC-Z 305 TPI upgrade
Car: 1987 Camaro Iroc-Z Z28
Engine: 305 FI
Transmission: 5Speed
Axle/Gears: Stock
hi im trying to look for upgrades for my Iroc Z 305 5speed because im trying to build my car to race my brother on the track.
My bro has an 86 Mustang GT Foxbody with a 302, E303 cam(dont know the lobe lift or cam degree) and 4.10:1 ring an pinion.
i was wondering if there was any good upgrades that anyone can recommend?
cams, heads, Ring and Pinion, Etc.
thanks
thanks
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 87 IROC-Z 305 TPI upgrade
The cam in my signature will work very well, and you could get your heads ported and upgraded for added valve-lift.
There is also info in my signature links for upgrading to LS1 valves & beehive springs.
Exhaust upgrades: stainless headers, Y-pipe and cat-back system are always good for a very significant increase in power.
TPI really doesn't respond well enough to rear-gear upgrades to make it worth the trouble, unless you get the gears cheap and do the install yourself. With a manual trans too much gear could create more of a problem in a drag race.
Do a search on this forum for modifications to the factory camaro Y-tube intake air duct & air filter boxes.
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I would recommend 3.73 gears and the Crane 2032 cam. Great combo and a lot of people run it. Requires no special ECM tuning.
This cam works great in 305 and 350 cars. http://crane.carshopinc.com/product_...d/15861/104224
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. What E.T. and MPH your brother running? What's Your's? Which rear end ratio?
.. As 305sbc mentioned, headers and at least 3" maintube exhaust/mufflers is the starting point... along with freeflowing aircleaner setup...
.. The stock TPI setup works better on the 305 engine than it does on larger engines...
.. A more modern super strong roller cam is the GM #12370845 214/224 .488/.509 valve lift LSA 112 (also has fuel pump eccentric for carb.'d engines)
http://www.gmperformanceparts.com/si...mallBlocks.jsp
Car: 88 IROC
Transmission: Many
Axle/Gears: Many
.. Naw, that new GM cam is just a modernized version of the Crane cam... same tuning, just more lift for more torque by 4500 RPMs on a TPI engine... just needs some good Z28 valve springs... will also work for carb.'d engines, as well...
Engine: 305 FI
Axle/Gears: Stock
I do not have anything modified beside k&n filters and 3" exhaust. Other than that dully stock. I do not have an et or mph on my bros mustang.
Transmission: Many
Axle/Gears: Many
.. No headers? Your bro's Mustang might be running 16's at 85 MPH or 12's at 115 MPH... gotta kinda know what you're up against...
Engine: 305 FI
Axle/Gears: Stock
no headers yet im planning on ordering some now but im researching on which ones are the best. and i got my brothers mustangs time. he has a 13.26 at 112 mph. when i raced him yesterday he got ahead of me 1 car length. non of my freind's were recording so i do not have the time or mph for it. i just have my bros mustang from january
Sanjay
Aug 12, 2015 03:41 PM
