081 Head Swap, Is it Worth it?
Old Dec 28, 2011 | 02:05 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok a few weeks ago I bought a 88 Iroc with a 350 TPI, beside it needing a donut gasket it seems to run fine. Well the other day out of sheer curiosity I popped the oil cap off the head cover and looked at the head casting numbers, well to my surprise these werent TPI heads, they were 187 casting tbi heads(swirlies), im assuming that the heads are completely stock with no work done to them. There is a guy on this site who is selling a set of 081 TPI heads with a couple extras put into the heads. He says that they have the following upgrades:
- 1.94/1.55 Valves
- Machined Valve Guides with springs for .525" lift
- slight bowel port work
- Pressed in studs removed for screw in units with guideplates
Well i have a little extra cash after the holidays from my parents and what not and I was wondering would I see a significant gain by swaping the 187 heads for these 081 TPI heads?... I ask because alot of people on the site say that the swirl port heads take away from the performance of the tpi but I have also read that swapping a stock head for another stock head will probably not be much of a gain.
I know you guys are going to say just get some aftermarket heads but I dont really have money for aftermarket heads as I am a College student living on my own and i believe the heads that he is selling are ready to bolt on so thats right in my range lol.....
PLEASE HELP GUYS, I need input asap because the guy should be getting back to me with the shipping quote soon.......
Old Dec 28, 2011 | 04:28 PM
dredre08's Avatar
Re: 081 Head Swap, Is it Worth it?
Anybody?????
Old Dec 28, 2011 | 04:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its worth it.
Old Dec 28, 2011 | 04:32 PM
dredre08's Avatar
Originally Posted by TTOP350
Its worth it.
Do you think it will be a noticable gain?....
Old Dec 28, 2011 | 07:55 PM
dredre08's Avatar
anybody else got any input
Old Dec 28, 2011 | 09:31 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if you're pulling the heads, I wouldn't put stock 081s back on unless they were heavily ported by an experienced porter with flow bench data to back it up. I'd be looking for over 250cfm on the intake side at .500 lift as a benchmark, and to use that you'll need to fully port your stock intake parts at a minimum. Stock for stock I don't think you'll pick up enough to make it worth while. I put swirl port 305 heads on a TPI 305 I built a few years ago and it ran great. With a stock cam, stock intake, and especially stock exhaust I really don't think it will be worth it.
Old Dec 28, 2011 | 09:38 PM
Damon's Avatar
If it's actually a 350 (I'd check since it's obvious you have a "frankenstein" motor with at least mismatched heads) those little 305-sized 187 swirlies are choking it pretty bad. The correct TPI heads for a 350 would be -083 castings. Worked -081s would probably be about equivalent to them flow-wise, maybe even a bit better depending on how good the bowl and seat work is.
You have any idea the specs on that motor besides the heads? Would be nice to know what kind of cranking compression you have as well.
305-sized heads are great for building compression on a dished-piston 350 bottom end to get compression up into the mid 9s. But if the bottom end of that "350" already has flattop pistons you could be looking at almost 11:1 compression- too high.
Old Dec 28, 2011 | 09:57 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
You're right I missed this. The 187s will be bad news on most 350s unless it's got dished pistons or something. Pull the casting number off the bellhousing pad behind the driver side cylinder head and see what you have. it might just be an L03 dumped in there...
Old Dec 28, 2011 | 10:01 PM
TTOP350's Avatar
I guess I should have said its worth it to ditch the TBI heads...
Old Dec 28, 2011 | 10:02 PM
dredre08's Avatar
Im going to check that first thing tom...... I was thinking the same thing when I seen the heads, the guy told me that it was not the original motor but he said it was a 350, and it seemed to have a noticeable amount more power then my old 305tpi that I had in my old trans am... I hope i didn't get burned!!
Old Dec 28, 2011 | 10:13 PM
dredre08's Avatar
matter fact im about to go check now!!!, is removing the bellhousing hard to do??
Old Dec 28, 2011 | 10:24 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
LOL you don't have to remove anything, just look at the flat pad behind the driver side head. IT is hard to see in the car but its the only way you'll know what you have.
Old Dec 28, 2011 | 10:26 PM
dredre08's Avatar
Is it by the alternator??
Old Dec 28, 2011 | 10:33 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
no. back of the engine by the firewall
Old Dec 28, 2011 | 10:36 PM
TTOP350's Avatar
No its the rear driver side. by the brake booster/ firewall area.
Old Dec 28, 2011 | 10:45 PM
dredre08's Avatar
lol im probably going to have to let someone else who is a little bit more knowledgeable about engines, Im looking where you guys are telling me to but its impossible to see through all these wires or im just looking in the wrong spot.......
Old Dec 28, 2011 | 11:23 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
If your going to spend a few hundred bucks throw in a couple hundred more and at least vortec or aluminum vett heads. Stock parts deliver stock performance.
Old Dec 28, 2011 | 11:30 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. Below distributor on bellhousing on driver's side... use a flashlight... or possibly on passenger side in front of head...
.. I wouldn't change the heads... keep your money and get through college... the current cam prolly isn't taxing the 187 heads...
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
