Vacuum and Cooling lines
Old Jan 5, 2012 | 11:46 PM
92chevyz28's Avatar
I need help with figuring this one out i recently had to change the fuel injectors and unplugged a few hoses i cant remember, one is from the evac canister on the drivers side right behind the headlight, The center tube i dont know where it goes to thats in pictures 1 and 2 I read where some say it should t off and connect to the under valve of throttle body but mine dosent T off and im pretty sure that goes to egr valve solenoid. The second is long vacuum tube coming from the a solenoid connected to the accelerator that splits off and goes to something under the fender and the other half i dont know what connects to, thats in pictures 3 and 4. Another thing is the throttle body, I have 3 outlets on the passenger side top one goes to passenger valve cover, and the bottom goes to heater valve if im correct, what does the middle smaller one go to? Any help is greatly appreciated.
Attached Thumbnails Vacuum and Cooling lines-photo-1-ed.jpg   Vacuum and Cooling lines-photo-2-ed.jpg   Vacuum and Cooling lines-photo-3-ed.jpg
Old Jan 5, 2012 | 11:48 PM
92chevyz28's Avatar
Re: Vacuum and Cooling lines
Here is the 4th picture
Old Jan 7, 2012 | 06:46 PM
92chevyz28's Avatar
Solved thanks anyways
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
