305 carb to tpi
Old Jan 9, 2012 | 09:12 PM
schiller_18's Avatar
305 carb to tpi
hey guys im putting a tpi system on my 305 i bought a system for 150 bucks off craigslist i got upper and lower intake with tubes complete wiring harness computer and distributor the guy said it came off a 86 camaro iroc z 305. what i need to know is what all sensors do i need to put on my 305 to get this to run i know i need a knock sensor and maf sensor but what else? also with it being a different 305 than the iroc motor will the maf sensor read with my stock 305 cam or do i need to get a stock 305 camaro tpi cam any help will be appriciated kinda new to the tpi systems thank you.
heres some pics of what i bought
Attached Thumbnails 305 carb to tpi-2012-01-09-20.50.08.jpg   305 carb to tpi-2012-01-09-20.50.35.jpg   305 carb to tpi-2012-01-09-20.50.59.jpg
Old Jan 10, 2012 | 05:02 PM
Re: 305 carb to tpi
ok so i did some research and found out i need
MAF senor power relay and burnoff relay
knock sensor
coolant temp sensor
fuel pump and sending unit
fuel pump relay
is there anything im missing to get this to work thank you
Old Jan 11, 2012 | 08:11 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 305 carb to tpi
If your car didn't come with a speed sensor, then you will need that.
VSS.
Old Jan 11, 2012 | 10:45 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: 305 carb to tpi
If you go to my webpage ( see my signature) I have a page on my TPI swap. This is where I have downloaded lots of files and info. There is a spreadsheet with all of the parts I used, with cost, etc. Lots of other useful links there as well, including all my links to other websites.
You ECM with the MAF should be able to accommodate the cam with no issues.
For sensors, you will also need the TPS and IAC in the throttle body- may have been included with what you bought.
https://sites.google.com/site/darbyselky/home
Old Jan 11, 2012 | 08:04 PM
Re: 305 carb to tpi
thank you guys for the help and the link you gace me really helped
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
