loosing air and smog pump. is that ok
Old Jan 23, 2012 | 08:13 PM
1988TransAm22s's Avatar
Car: 1988 TRANS AM procharged
Engine: 305 procharged TPI with 5 speed
Transmission: 5 speed
Axle/Gears: 3:73
just like the title says... i have a 88 trans am with a 305 tpi witha 5 speed.. i no longer want to have air because i have t tops and the air doesnt work that good anymore.. i would replace the pump with a pulley and the next questions is i also want to get rid of the smog pump because we have no emission laws where im at... the biggest questions i have is can i do this without making my car run like butt.. or is there a way to do this without hurting my performance or the way my car runs... i hreally also dont like how it looks under my hood on the pass side due to all the xtra crap they stuffed in there.. please help so i know if i shoud pull it or not.. thank you very much
Old Jan 23, 2012 | 08:33 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: loosing air and smog pump. is that ok
You can do this without causing anything major to go wrong. At a later date if you ever get the car tuned or recalibrate your EPROM yourself you can make some adjustments for the changes.
Removing the AC system will usually cause your cooling fan to run until you jump the pressure switch that is on one of the aluminum AC lines.
Your CAT may not live very long after you remove the AIR system.
Don't forget to address that at some point, though it's not an emergency or anything.
Your closed-loop function uses an O2 sensor offset for certain modes of the AIR system operation. Without the AIR, you might notice very small changes in your cold-start or idle, but it is normally not very noticeable.
As long as you're getting rid of stuff you might consider swapping to an S10 manual steering box. You may then be able to configure your belt so that you don't need the extra delete pulley, and run a much shorter belt.
Old Jan 24, 2012 | 08:46 PM
Axle/Gears: 3:73
well the good news is i dont use the stock fan set up so thats not an issue as for the cat thats not going to be there much longer after i take it off..thank you for all the information. when i go to tkae the stuff out i will repost if i have any issues.
specialized
Jun 18, 2022 09:26 AM
chazman
Aug 28, 2018 03:25 PM
mike40sm2
Sep 1, 2015 02:15 AM
Dialed_In
Aug 20, 2015 01:45 PM
jackhammer
Aug 15, 2015 10:04 PM
