rolling idle
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
rolling idle
so,heres my deal . my camaro idles wonky,it goes up and down, sometimes it will stall. upon restart it idles high then it settles down to 500-750 rpm then the process starts all over, im showing a code 44 lean condition too but my CEL is not on all the time.when i go for fuel theres a big whoosh ,isnt the charcoal can vent valve supposed to relieve tank pressure? if the diaphram in the top of the charcoal can is failed would that cause the vaccum leak (CODE 44) and the excess pressure in the tank? AND the idle problem??? any help here ? cause im stumped. my car;86 iroc tpi 305 bone stock
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: rolling idle
