Need Fuel Pump advice ASAP
Car: 1987 Pontiac Firebird Trans Am
Axle/Gears: 3.45
I was going to buy Walbro 255 LPH fuel pump but found this one that claims to be almost the same and even quieter:
http://treperformance.com/i-63603-po...1985-1998.html
I need to buy 2 so it makes a difference.
What I want to know is:
Is it worth it? Has anyone tried it?
Thanks.
Thanks.
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: Need Fuel Pump advice ASAP
Unless your engine NEEDS that much extra fuel, just use the factory pump. The extra fuel can lead to overheated fuel in the tank, which leads to pressure problems.
Cheers
edit: I used to use the 255 LPH, but I am convinced that it contributed to my overheated fuel problems and drivability issues.
Cheers
Axle/Gears: 3.45
After the CAM that I installed it need some extra fuel so I guess that won't be a very big problem...and I'm not stopping there either so... :-)))
Thanks for the advice I'll keep that in mind :-)))
Engine: 4++,350 & 305 CIs
I use the walbro 255 in my cars that are stock and have 0 problem.
I also use 2 of them in the tank of another of my cars.
The one in the link looks like it could be a overseas knockoff of a walbro??? Make sure before you buy it and have issues..
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
