TBI L03 to MAP L98 - MAP sensor location question
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Since my TBI uses the same MAP and it has the bracket that mounts it along the firewall can I just keep it located there and run a vacuum line to the plenum? Also The plenum now is from a MAF car so I need to tap into some type of vacuum, which line should I 'T' off? Or should I tap right into the plenum and what would I use if I do that?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TBI L03 to MAP L98 - MAP sensor location question
Axle/Gears: 3:42
Your tpi plenum should have a spot for the map sensor on it. If not let it hang with a short hose,just as long as it doesnt get moved around much
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Only if it came off a MAP TPI engine
MAF plenums don't have the threaded hole for the MAP bracket or the 3rd vac port to connect to it
There are only 2 vac ports on the MAF plenum.
Use one only for the MAP sensor and T off the the other port for the fuel reg / EGR / HVAC controls
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I ran into this problem and put a third vacuum fitting in the plenum (mine was from a MAF car). I tried "t-ing" the vacuum and always had something to not function properly. As for the sensor mount I reused the TBI location on the firwewall and ran a line to the port on the plenum and the car has never had any problems related to it.
Engine: 4++,350 & 305 CIs
If you relocate your MAT sensor thats under the plenum to someplace in the air intake, you could put a 90deg hose fitting in that port just for your map sensor.
Car: 82 Z28
Transmission: T400
Engine: 5.7 L98
what kind of a vacuum fitting did you use and where did you put it?
Car: 90 Formula
I just used another GM fitting (not sure the size),drilled and tapped the hole in the area just behind the passenger side runner. Be careful to check the thickness of the material in this area, the first plenum I used had plenty but the second one that I ported and siamesed was thinner. Don't ask me why 2 plenums with the same p/n had this difference.
92camaroJoe
Aug 13, 2015 06:07 AM
