350 tpi ????
Old Feb 8, 2012 | 04:58 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
350 tpi ????
Ok 350 tpi I finally got it running an Idling somewhat smooth my question is I'm getting some hesitation when I give it the throttle what could be the problem so far I changed wires, spark plugs an the cts
Old Feb 8, 2012 | 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 tpi ????
Some more info would be handy.
Is this a fresh install ,
a engine that had problems and was not running
or what.................??????????????????????
Have you checked the codes 1st?
Old Feb 8, 2012 | 10:27 PM
Engine: LR4 4.8
Re: 350 tpi ????
Sorry about the whole making a new thread of the same topic something weird happened saying it expired, ok so here's the situation when I first got the car home it was running really rough few ignition wires were cracked causing misfire, no 02 sensor was installed into the heddman headers so I fixed that the cts connector was broke fixed that, the motor has 111,000 on it oil pressure is around 30 psi, temp runs aroumd 190 an is steady no engine light is on at the moment. Starts up fine an idles it's just when I give it the throttle it takes a few seconds to climb up through the rpm's. I've replaced the spark plugs with ac delco r45ts with 10mm Taylor ignition wires. Havent got to change the cap an rotor yet for the dizzy, nor have I checked fuel pressure or checked the fuel filter, I do have a new fuel filter but I have to change acouple of lines fuel lines are starting to rot out pretty bad, alsO along with the brake lines
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
