Pintle cap question.
Old Feb 11, 2012 | 07:45 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Does a TPI motor come with these?
Napa online shows them without...just wanted to know what they are for and if the TPI engines used them.
Old Feb 14, 2012 | 04:21 PM
Mr Froman's Avatar
Re: Pintle cap question.
Bump.
Anyone?
I'm talking about the plastic tips that pop on the end of the injectors:
http://www.google.com/search?tbm=isc...0l86l432l7l7l0
Old Feb 14, 2012 | 04:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It will depend on witch year / model of injector being used more seen in 85-88 tpi multi-tech's 89-92 tpi do not use these design.
Old Feb 14, 2012 | 04:40 PM
Engine: Lb9
Transmission: M20
If you are going to replace your injectors check out the bosch 3 at southbay fuel injectors.
http://www.southbayfuelinjectors.com...tors_More.html
Old Feb 14, 2012 | 05:15 PM
southbay08's Avatar
Thanks tunedperformanc.
Mr. Froman, those plastic caps are called pintle caps. They snap onto the bottoms of most of the bosch gen ll fuel injectors. They are used to hold the bottom oring in place. Again, these pintle caps are on the older metal body injectors, and yes,
tunedperformanc is correct they are not used on the multec injectors.
Old Feb 14, 2012 | 07:50 PM
Mr Froman's Avatar
I have Linder injectors
Old Feb 14, 2012 | 07:55 PM
southbay08's Avatar
ok, well...either way, the plastic pintle caps hold the bottom orings in place.
Old Feb 15, 2012 | 06:09 PM
Mr Froman's Avatar
Old Feb 20, 2012 | 05:22 PM
Mr Froman's Avatar
Alright, another question.
Does it matter what pintle cap goes on the injector? Will the "universal" pintle caps work?
Old Feb 20, 2012 | 07:31 PM
southbay08's Avatar
you sent me a link to an injector on our website. Those injectors are bosch gen ll's.
The pintle caps that we use for those injectors are universal
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
shanelique22
Sep 24, 2015 06:30 PM
Saxondale
Sep 15, 2015 06:42 PM
Ian Irvine
Sep 4, 2015 08:08 AM
