tpi engine harness questions
Old Feb 14, 2012 | 08:44 PM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i have a 1989 camaro with tbi and a t5 can you use a harness and computer out of a 1991 tpi with a 700r4 just dont use the speed sensor plug in or the torque lock up pigtails i was wondering if this would work since im having a very hard time finding a tpi with t5 harness and computer i was thinking it should work but im not a 100% sure
Old Feb 15, 2012 | 01:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi engine harness questions
That would be doing a speed density (MAP ) swap ;you would reuse your TBI MAP sensor.
Otherwise same as MAF TPI swap except no MAF or MAF relays needed
Is usually advised to connect the VSS because it controls revs when you slow down at a stop, even though you don't need it for the man trans
read
http://www.edgesz28.com/edgesz28/sub...tuning.htm#vss
Could fit correct the 4000 pulse VSS from a 90 -92 TPI trans or if you have cable drive speedo
use this to give correct signal to computer
http://tpiparts.net/inc/sdetail/10956/7587
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
