Stock Runners? Modified 355
Old Feb 13, 2012 | 10:24 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Im in the process of putting a tpi back on my 86 iroc. The original engine was removed(305 tpi), and I put 355 with high flowing heads and a moderate hyd roller cam in its place. I am trying to figure out if I need to go with better flowing runners.(slp?) I have upgraded the injectors (22lb) and am programming a chip to match. I have a holley 670 carb that seems to be well matched to the engine, but am excited to get the tpi back on.
Sorry if youve had to answer the same kind of question a bunch of times, but any advice would be much appreciated!
Old Feb 13, 2012 | 10:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Stock Runners? Modified 355
Originally Posted by irockid43
moderate hyd roller cam in its place. d!
What specs on cam?
Stock TPI intake is known restriction to top end performance so anything you can do to improve flow will add power potential
Old Feb 14, 2012 | 12:07 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Yeah, ive heard that the runners were the most restricted part of the top end. The cam Im running has 206-212 duration and 480-487 lift. With the carb Im getting power up past 6000rpm, Im hoping to get good flow from the tpi and not lose the top end power.
Old Feb 14, 2012 | 12:25 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The stock top end can support 400hp/500ft lbs, You think you'll exceed that with the 355?
Old Feb 14, 2012 | 01:02 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
But flatlines at 4500
Aftermarket intakes will run past 6K
Old Feb 14, 2012 | 08:12 AM
Car: GTA
More like 4750/5000, but it comes down to the Owners desired usage of the vehicle. On the street, 4500 is plenty. For drag racing higher rpms might be. But a higher rpm range also costs you bottom end torque.
For a primarily street car, I'd gladly sacrifice the above 4500rpm horsepower to gain bottom end torque. For the drag strip I'd go for rpms too.
I constantly see people quick to dismiss TPIs rpm range when no consideration is given to the intended usage.
Old Feb 14, 2012 | 08:38 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I think a FAST TPI intake would work well with your combo. It will allow you to keep that low end torque, but let you breath uptop and not waste your cam. Your set up with that intake and a spot on tune will make a really fun street car that should be easily into the 12's.
Old Feb 14, 2012 | 10:17 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Thanks for the info guys. I forgot to mention that my heads have been ported and polished too. Ive been trying to find cfm specs on the stock runners compared to slps. Im wondering how much of a difference bigger runners can make? What is a Fast TPI intake?
Old Feb 14, 2012 | 10:26 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
are u keeping the 273's? then if you are you better go for a low end torque street car. How are u using the vehicle? track only? street?
Old Feb 14, 2012 | 11:41 AM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
I would love to change the rear end gears to 3.73s, or 3.42s. Its just a street car, but not a daily driver. I feel like the gears are way too high right now. Do you guys think that upgrading the runners sacrifices low end torque?? I am just kind of wondering the difference in performance between stock and aftermarket runners, and I guess trying to confirm that they are the most restrictive part of the intake? Maybe someone has done this upgrade and was happy or unhappy with the results?
Old Feb 14, 2012 | 12:28 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unported the SLPs will show very little gain. You have to port the !!!! out of them to be worth it. then you need a bigger or ported base.
Old Feb 14, 2012 | 12:58 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
The heads are your biggest bottle neck with the TPI motors. You have updated heads so I think you will see nice gains. I have the Edelbrock intake set up on mine. And I'm pretty happy.
Old Feb 14, 2012 | 02:12 PM
ninetyone's Avatar
Axle/Gears: 3:42
you will lose a little low end,it will mainly shift your powerband up a little. the same torque you had at like 3k rpm will now be seen at 3500 but you may see like an extra 10 ft/lbs. That is basically how it works. Just so you know, if you are running a 700r4 transmission,then 342's would be the max gear i would use. I have 342 and almost have no 1st gear now and feels like i need to shift again after 65. So that gives u an idea. I say stick with the stock runners UNTIL your requires bigger runners.
Old Feb 14, 2012 | 02:14 PM
ninetyone's Avatar
Axle/Gears: 3:42
i think your looking at like 10hp on a stock motor and they cost $300+.
Old Feb 14, 2012 | 02:35 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Before you look into a gear in the rear end, think about the cost. You probably have a series 2 carrier. Series 2...you can only go to a 3.08 gear....its not worth the $$ in my opinion.
Anything more then that your going to have to jump to a series 3 carrier. And if your going to be spending the $$ I would go with 3.73....I have had them in my car for 6 years...wouldn't change a thing! People who think 3.42's are the best....haven't driven a car with 3.73's LOL!!
Old Feb 14, 2012 | 02:43 PM
ninetyone's Avatar
Axle/Gears: 3:42
you can pick up a used rear for $150 from a junkyard. Sometimes with 342 or 323's in them. I remembering reading an article on a 91' TPI car that went from 342 to 373 and gained nothing. Maybe a better 60ft time.
Old Feb 14, 2012 | 02:46 PM
ninetyone's Avatar
Axle/Gears: 3:42
Remember he only has 273's. I gained like 3 tenths from my 342 swap! Feels like 100 ft lbs of torque. Even my wife said the car felt like it had a supercharger or something on it
Old Feb 14, 2012 | 06:39 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Yeah, I would like to use the 3.73s.. I think. What kind of rpm are you running at 60mph?
Old Feb 14, 2012 | 07:04 PM
ninetyone's Avatar
Axle/Gears: 3:42
suit yourself
Old Feb 15, 2012 | 07:15 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
and imagine what she would have said if you installed a 3.73
It's not like hes going to the track racing every week. Hes an in town driver who like the streetlight to street light race. Or likes the feel of goosing the gas pedal off the start.
You want to get even better throw a little stall in it. Do some research, a stall out of a S10 truck / blazer bumps up the stall a little, that's cheap too. And that's just a stock GM converter. I think our cars stall around 1200 this bumps it up to 1700.
Old Feb 15, 2012 | 07:39 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Remember the 3.07 1st gear of the auto gives plenty of torque multiplication
In 1st gear ,2.73 rear w/ T700 is equal to old skool 3spd auto with 3.4's
3.42 is equal to old skool auto w/ 5.10's
Probably running out of top end w/TPI
Old Feb 15, 2012 | 07:51 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
https://www.thirdgen.org/forums/tran...4-11-whos.html
here is a link to the mph / rpm's it shows 3.73's also
84z96L31vortec
Aug 20, 2017 12:16 AM
Linson
Aug 21, 2015 02:12 PM
theurge
Aug 21, 2015 12:46 PM
marcusaw
Aug 10, 2015 08:13 AM
