700r4 with 4.11 who's done it?
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi Folks,
I at the moment have a 700r4 with 3.23 gears >>> im bored with it To those that have installed a 4.11 gear set How are the street manners? what kind of cruise rpms are you now running? I also have a coan 3200 10 inch converter
what are your opinions on this set up thanks >>>> GTA
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 700r4 with 4.11 who's done it?
Id like to know how a 700 with 4:11's are on the interstate form like 75 to maxed. Im sure I have read a post like this before but cant remember
o well suscribe and see where this goes
Engine: 4++,350 & 305 CIs
I have, intown fine, highway I wasnt to fond of it. Im running 3.73s now.
I did these with a 26.6" tire and a 700r4 overdrive gear ratio
4.11s
Engine Speed (RPM) Speed (MPH)
8000 RPM 211.01 MPH
7500 RPM 197.82 MPH
7000 RPM 184.63 MPH
6500 RPM 171.44 MPH
6000 RPM 158.25 MPH
5500 RPM 145.07 MPH
5000 RPM 131.88 MPH
4500 RPM 118.69 MPH
4000 RPM 105.50 MPH
3500 RPM 92.31 MPH
3000 RPM 79.13 MPH
2500 RPM 65.94 MPH
2000 RPM 52.75 MPH
1500 RPM 39.56 MPH
1000 RPM 26.38 MPH
3.73
8000 RPM 232.50 MPH
7500 RPM 217.97 MPH
7000 RPM 203.44 MPH
6500 RPM 188.91 MPH
6000 RPM 174.38 MPH
5500 RPM 159.85 MPH
5000 RPM 145.31 MPH
4500 RPM 130.78 MPH
4000 RPM 116.25 MPH
3500 RPM 101.72 MPH
3000 RPM 87.19 MPH
2500 RPM 72.66 MPH
2000 RPM 58.13 MPH
1500 RPM 43.59 MPH
1000 RPM 29.06 MPH
3.27
8000 RPM 265.21 MPH
7500 RPM 248.63 MPH
7000 RPM 232.06 MPH
6500 RPM 215.48 MPH
6000 RPM 198.91 MPH
5500 RPM 182.33 MPH
5000 RPM 165.76 MPH
4500 RPM 149.18 MPH
4000 RPM 132.60 MPH
3500 RPM 116.03 MPH
3000 RPM 99.45 MPH
2500 RPM 82.88 MPH
2000 RPM 66.30 MPH
1500 RPM 49.73 MPH
1000 RPM 33.15 MPH
4.11s
8000 RPM 211.01 MPH
7500 RPM 197.82 MPH
7000 RPM 184.63 MPH
6500 RPM 171.44 MPH
6000 RPM 158.25 MPH
5500 RPM 145.07 MPH
5000 RPM 131.88 MPH
4500 RPM 118.69 MPH
4000 RPM 105.50 MPH
3500 RPM 92.31 MPH
3000 RPM 79.13 MPH
2500 RPM 65.94 MPH
2000 RPM 52.75 MPH
1500 RPM 39.56 MPH
1000 RPM 26.38 MPH
3.73
8000 RPM 232.50 MPH
7500 RPM 217.97 MPH
7000 RPM 203.44 MPH
6500 RPM 188.91 MPH
6000 RPM 174.38 MPH
5500 RPM 159.85 MPH
5000 RPM 145.31 MPH
4500 RPM 130.78 MPH
4000 RPM 116.25 MPH
3500 RPM 101.72 MPH
3000 RPM 87.19 MPH
2500 RPM 72.66 MPH
2000 RPM 58.13 MPH
1500 RPM 43.59 MPH
1000 RPM 29.06 MPH
3.27
8000 RPM 265.21 MPH
7500 RPM 248.63 MPH
7000 RPM 232.06 MPH
6500 RPM 215.48 MPH
6000 RPM 198.91 MPH
5500 RPM 182.33 MPH
5000 RPM 165.76 MPH
4500 RPM 149.18 MPH
4000 RPM 132.60 MPH
3500 RPM 116.03 MPH
3000 RPM 99.45 MPH
2500 RPM 82.88 MPH
2000 RPM 66.30 MPH
1500 RPM 49.73 MPH
1000 RPM 33.15 MPH
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
in city i am fine....on highway going 65-70mph i am at like 3200-3500 rpm...so sometimes i wish i went with 373s...but it depends on how much you drive on highway
and i have a 4.10 gear with 700r4
Car: 1992 Z28 "clone"
Engine: 355
Axle/Gears: Moser 12 bolt w/ 4.11s
I run a 700 w/ 4.10s and a 3000 stall. My car runs 10.9s @ 124 , 1.51 60ft and it works very well. The low first really makes for a good launch, even at a lower stall speed. As for cruising, it is good for 70 mph at around 3000. If you dont plan on highway driving all the time, its the best combo in my opinion.
i agree on that...i love the speed in the city..etc...i haven't got to race it yet..new motor and trans....i have a 2400 stall and like he said...3000 rpm on highway speeds....65-70 . but how often do you drive on highway...if alot then..go 3.73.... or 3.52
Car: 1992 GTA
Engine: running
Axle/Gears: both
hmm, i do do mostly high speed highway driving...maybe 3.73 is much better suited to my needs? I wonder if there is enough of a perf boost to warrent going from 3.23 to 3,73?? opinions?? thx GTA
yeah...also you got to remember with higher gears you will start out faster but run out of gear..my top speed is like 100 and the car is screaming..which is fast dont get me wrong...and the only difference in a 3.73 and 4.10 is 1 tooth....same ring gear...pinion gear on 4.10 has 1 less tooth thats it. i bet 3.73s will be good...also motive gear makes a 3.90 gear ...if you want to be better than3.73 but not a tall as 4.10...just another idea...but if i had to do it all over again i would do 3,73
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
go with the 4.10 gear. and buy 28" tall rear tires. with the 700R4 works fantastic!
4.10 rear gear .73 trans 28" tire
8000 RPM 222.11 MPH
7500 RPM 208.23 MPH
7000 RPM 194.35 MPH
6500 RPM 180.47 MPH
6000 RPM 166.58 MPH
5500 RPM 152.70 MPH
5000 RPM 138.82 MPH
4500 RPM 124.94 MPH
4000 RPM 111.06 MPH
3500 RPM 97.17 MPH
3000 RPM 83.29 MPH
2500 RPM 69.41 MPH
2000 RPM 55.53 MPH
1500 RPM 41.65 MPH
1000 RPM 27.76 MPH
8000 RPM 222.11 MPH
7500 RPM 208.23 MPH
7000 RPM 194.35 MPH
6500 RPM 180.47 MPH
6000 RPM 166.58 MPH
5500 RPM 152.70 MPH
5000 RPM 138.82 MPH
4500 RPM 124.94 MPH
4000 RPM 111.06 MPH
3500 RPM 97.17 MPH
3000 RPM 83.29 MPH
2500 RPM 69.41 MPH
2000 RPM 55.53 MPH
1500 RPM 41.65 MPH
1000 RPM 27.76 MPH
see there. right in the ball park. even in this state 70 on the Hy. is the limit.
with the 4.10 you dont even need passing gear..(i never did)
just tap it. and your gone! (my car anyway)
unless your a stock eng tree hugn long hair. and dont like your eng to be any place near 2500 rpm
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
With a 4.10 gear and WOT in 4th gear, your trans wont last long.
I think you would be better with a 3.73, and drag radials, unless you just want to roast your tires all day long
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Car: '91 GTA
Engine: 421sbc
Spinning ain't winning.
Back when I had a 14 second car, that's all I wanted to do was spin my tires.
Now that I have a 11 second car(and want to go alot faster), thats the LAST thing I want to do is spin my tires.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
No need to swap gears, just change your tire size to reach the same goal...
Car: 1986 Camaro
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Don't change them. You have a stock car. No benefit except for quick starts. But you get dusted after 4800rpm. These other guys have race cars giving advice has race cars. Your situation doesn't apply.
MID TENS. back in the 90's. that was old school stuff. even with 4.11s and 28" tall tires. pulling the wheels and still doing 70 on the interstate to the track. even with MT ET streets. no spinning. just good old traction
700R4 loved it!
even getting into a top end race to the track with buddys. but then we make um to turn some RRRs.. after all. its all for fun.
still using the 700 today just doing the 5 pinon upgrade front and back with the good sunshell also.. we dont use a stock 700R4. lots of good upgrade stuff today.
700R4 loved it!
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Yea I know. It's only good for the 1/8mi in a Stock TPI. 3.23 will beat it in the 1/4mi. 98mph in the 1/4 with 3.73, 101mph in the 1/4 with 3.23 with a full exhaust system. Maybe with the same ET.
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
i went from 2.73 to 3.73 on my vert. and though it's quicker.... not so fond of it on the highway. i do alot of highway driving and i hate to go over 2500 cruising. i run 245/35ZR20's which i think according to the excel calculator makes it around a 27" tire. if i did more city driving i'd probably like the 3.73's better, but i got them with the intention of going GVO or T56 down the road....
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I have 4.10s and like them. I do about half and half city/highway. Its very easy with them to break the tires loose. I have 285/35/18 nitto's and can roast them from a stop well into third. Even at the track its a struggle to hook with slicks. The 373's I had prior were certainly better for traction, but I still dont regret going to 410's.
4.10's is good if you're shifting 6000+ with a tall tire. TPI is only good to 4800. So why use 3.73 or 4.10's if your not making power pass that. Its hurting you!
darwinprice
17
Oct 11, 2015 11:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
" hahah
