TPI Harness
Old Feb 16, 2012 | 05:58 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
TPI Harness
Will a tpi harness from a 90 camaro fit a 91 camaro? Didn't know if the drivers side pigtail had the same pin out.
I can get my hands on a 90 complete tpi setup with harness and computer for 100. My 91 tpi harness is crap and need a new one.
Old Feb 16, 2012 | 06:21 AM
jpossibul's Avatar
Car: 1985 Black and Gold Trans Am
Engine: 305 Tuned Port Injection
Transmission: T5 Borg Warner Manual 5-speed
Axle/Gears: 3.08
Re: TPI Harness
I am not for sure but I think they will. For what it is worth, I can tell you a little about the TA's (and they should be the same.) In the schematics of my haynes book, the latest changes were made after 89. I found out the hard way by trying to put a 91 harness from the dash in an 89 set up. They look remarkably similar till you try to hook them up. Someone correct me if I'm wrong but I think they are the same from 90-92.
Old Feb 16, 2012 | 07:29 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: TPI Harness
90-92 speed density harness are the same but different between camaro and firebird with regards to battery hookup. Camaro has a seperate extra harness for dual fans while the Firebird's is an integral part.
Old Feb 16, 2012 | 11:53 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TPI Harness
the under hood light and gauge ground are different as well between firebird and camaro. i found that out the hard way on my swap. as long as it is from another camaro you should be good to go.
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
