Getting new injectors. Questions
Old Feb 18, 2012 | 08:32 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Should i get Bosch III 19# injectors or 22# injectors. Engine is .030" 305 speed density TPI. I see some say they're running 22's and others the stock 19's. My 19's are still working but my idle is a little rough and the injectors are original. Is there any benefit to 22# injectors? thanks
Old Feb 19, 2012 | 08:31 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: Getting new injectors. Questions
I,ve always heard that the speed density system does not take as kindly to modifications such as larger injectors and larger cylinder bores without a chip burned specifically for that application(that may be the cause of your rough idle), as opposed to the MAF system.IMO, your engine may burn too rich with 22lb injectors. An adjustable fuel pressure regulator would probably be a good investment as well. Good Luck
Old Feb 19, 2012 | 08:46 PM
I rebuilt my whole engine minus injectors and regulator. I waited on those till I got the v8 swap finished. The PO of this engine replaced a couple injectors here and a couple there. That for sure means that they're no longer flow matched so that I believe is probably my biggest problem. The rough idle is subtle. Its a puff here puff there. They're just old. I'll stick with the 19# bosch III's
Old Feb 20, 2012 | 10:09 AM
southbay08's Avatar
Would stick with the 19's
www.southbayfuelinjectors.com
Old Feb 20, 2012 | 11:25 AM
Hey southbay I was the who contacted you via eBay about a combo set of injectors and adjustable regulator. Hit me up with a combo price. Red regulator. Zip code 49010
Old Feb 20, 2012 | 12:03 PM
southbay08's Avatar
hey musicfreak, shoulda told me you were a tgo member You are going to receive 10% off the set of injectors if you want to purchase them.
I will pm you.
db057
Sep 4, 2015 07:57 AM
hydrolic144
Aug 29, 2015 04:14 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
