Trick Flow Super 23 heads
Car: 1989 Firebird Formula WS6
Engine: LSX 347
Axle/Gears: 3.45 b&w 9 bolt
Hey everyone im new here on third gen, and have a question about Trick Flows Super 23 cylinder heads. Will the ports on my stock bottom plenum match those on these heads? I have an 89 305 tpi 5speed car. Thank yall very much.
Car: 87 Trans Am GTA
Re: Trick Flow Super 23 heads
I run the Trickflow 195 CNC heads. You need to get the ones made for the 87 and up cars with centerbolt valve covers and the 72* angle middle intake manifold bolts. Otherwise, you would need to change your lower intake manifold base or elongate the middle holes.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
ambainb
Apr 25, 2016 09:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
