just a quick cam question
Old Feb 23, 2012 | 08:23 PM
dirtycj5's Avatar
i have a motor from a 91 camaro. i just tore it down to do a rebuild. got to the lifters and there not roller but it looks like a stock gm cam.
is this normal? or was it a cam swap or motor swap. ill get the block numbers and cam numbers in a hour or so
thanks
Old Feb 23, 2012 | 09:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: just a quick cam question
This far down the track anything could have happened.
Is it a roller cam block ;
does it have the machined pads above the lifter bores and the three threaded mounts for the lifter retainer as shown in pic below?
If it doesn't then it is a flat tappet block which would explain the lifters.
If it is a roller block , could be a truck engine that used a roller block but came fitted with flat tappet cam at the factory
or some PO has swapped a flat tappet cam in
Old Feb 23, 2012 | 09:59 PM
dirtycj5's Avatar
Thanks for your reply it is not a roller block it doesent have the pads for the lifter retainers. But its a newer block it doesent have opening for a mechanical fuel pump and it has center bolt heads. So maybe its a repacement motor or a truck motor? Who know with these older cars and many owners lol
Old Feb 26, 2012 | 10:27 AM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
probably a truck motor. one piece rear main right? they're still good motors, i'd take a flat tappet 350 over a roller 305.
Cameeeero
Sep 18, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
