L-98 ignition rotor
Old Feb 26, 2012 | 07:44 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
L-98 ignition rotor
How everyone, I'm replacing the cap and rotor but have come to a sticking point. I can't get the old rotor off. Is it just a press fit? Is there a locking screw that I don't see? Please help.
Robin Bailer Destin,Fl
Old Feb 26, 2012 | 08:08 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: L-98 ignition rotor
it just pushes on.
rust and corrosion causes it to stick. if you can't pull it off, just twist it off. put a shop towel around it so the exposed contact won't cut you if you hand slips while trying to twist it off. the rotor has a small plastic tab up inside that will break off and stay in the slot on the top of the shaft. so make sure you remove the broken tab before you put the new rotor on.
make sure the new rotor is seated all the way, a little WD-40 on the shaft helps with installing it.
Old Feb 27, 2012 | 12:42 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Thanks, I did what you suggested and it worked. Thanks again
Old Feb 27, 2012 | 06:02 PM
DENN_SHAH's Avatar
no problem
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
MM2Robinson
Oct 1, 2017 09:16 AM
loud91rs
Oct 5, 2015 10:05 PM
Racerx974
Sep 19, 2015 10:16 AM
