TPI Swap Minor Headache - Suggestion needed
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So check out these pics... how am i supposed to run the heater hoses, more so the one closer to the d/s
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Swap Minor Headache - Suggestion needed
The lower bracket mounted on the coil is backwards , hope you got the fitting I sent you
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I saw some heater hoses on e-bay that had a 90 degree bend already in them after you turn the coil around they would give you more room.
Engine: 5.7 L98
NBrehm
Aug 25, 2015 11:49 PM
