Barely failed emissions NOx by .07 Any ideas?
Old Feb 27, 2012 | 02:11 PM
MrPink's Avatar
Car: 1991 Pontiac Trans Am
Engine: 305 TPI 5.0L
I passed everything except NOx. Legal limit is 3.5 - I had a 3.57.
Any tips on getting this down .07? This is getting ridiculous, I have replaced just about everything on the list of things to replace. Just need a quick tip to get this thing through. Any help would be appreciated!
Old Feb 27, 2012 | 09:46 PM
camarocasanova's Avatar
Re: Barely failed emissions NOx by .07 Any ideas?
Have you tried isoprophyl alcohol (heet) in tank?? Seems to help nox. Have you tried retarding base timing a few degrees?
Old Feb 27, 2012 | 10:24 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
An EGR is used for reducing NOx by recirculating exhaust and ultimately lowering combustion temps.
Has is been replaced? Do you have any codes stored? Try tapping it with the engine running, it may brake any carbon loose. Also, try some upper intake cleaner along with cleaning your throttle plate. The less carbon buildup, the less likely your EGR is to get stuck closed.
Old Feb 28, 2012 | 05:02 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
http://www.crcindustries.com/ei/cont...x?PN=05063&S=N
pick up a bottle and follow the directions,you will be all set.
Old Feb 28, 2012 | 05:12 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Lucas Octane Booster help me pass when my car barely fail too. It only cost $10.
Make sure your timing is set at 6 degrees.
Old Mar 1, 2012 | 09:51 PM
Damon's Avatar
Agreed with Vincent- make sure the initial advance is set at stock or even slightly retarded from stock spec. High NOx is caused by high combustion temps. Advancing the ignition timing a bit is great for power and efficiency but also raises the NOx readings considerably.
Set it back to where it runs best after you pass the sniffer and get it back home.
Papaginos
Sep 27, 2015 03:29 PM
inferno15
Aug 29, 2015 01:48 AM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
