iac re set tpi
Old Feb 29, 2012 | 12:06 PM
dez58pop's Avatar
iac re set tpi
hi ive got a 305 tpi in my anglia with all egr blocked etc ,its got a a larrys ecm in it , ive put a new iac valve in the throttle body ,started the car but ran really hi revs , ive been told there is a procedere to re set the iac , ive heard its bridge the a & b on diagonstics plug ,turn the ignition on ,then unplug the sensor on the iac ,then remove the bridge wire from a&b then start the car with sensor un plugged for around 30 secs at about 1800 rpm then blip the throttle turn the car off ,put the plug back on then iac sensor and re start the car and should have re set the iac vavled can anybody comfirm just so im not doing it wrong ,also will it give a fault code for iac vavle ,thanks
Old Feb 29, 2012 | 12:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: iac re set tpi
https://www.thirdgen.org/forums/post...610-post2.html
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
