air problem! valve seal replacement
Old Feb 29, 2012 | 04:15 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
its on tdc. put air to it and i can here the air in the motor releasing some where cuz air compresser keeps leaking off.
Old Feb 29, 2012 | 04:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: air problem! valve seal replacement
If you're at TDC during overlap, both valves will be slightly open. No matter how you do it though, you'll hear air escaping into the crankcase.
Old Feb 29, 2012 | 05:22 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok. thanks.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
db057
Aug 22, 2015 08:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
