determining year of engine
Old Mar 2, 2012 | 02:51 AM
racerx520's Avatar
i recently bought a rebuilt 350 TPI, the person who rebuilt it was unable to specify the year it was from and said he received the car from a friend after he was involved in an accident and rebuilt the engine as a rainy day project years after receiving the car (he makes a living off rebuilding mainly carb'd motors)
where on the engine (if possible) can i find a spot to determine the year so i can order the appropriate camshaft?
thanks
Old Mar 2, 2012 | 07:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: determining year of engine
thanks
Block casting # in bellhousing area will give a guideline ; could be on either side of block depending on the year
Cam related to engine year is not important ( little difference in the spec)
more important is whether it is flat tappet or roller style cam
Old Mar 2, 2012 | 01:59 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
The block casting number is not necessarily going to tell you what year the engine is. What you need to find is the casting date on the block. What you're looking for is a 4-5 digit code, starting with a letter, which designates the month (A=January, B=February, etc.). The next digit(s) will be the day of that month, and the last digit will be the last digit of the year it was produced (but not necessarily the year model of the car if it was built in, say, November). Sometimes they will put the last two digits of the year instead (example: 87).
Decoded Examples
F178 = June 17, 1988
C54 = March 5, 1984 (may also be cast as "C054")
Old Mar 2, 2012 | 07:25 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
but a guideline as to identifying if it was a flat tappet or roller cam block from the factory
Having been rebuilt only way of confirming is to open engine up because anything could have been done to engine in the past
Plenty on here have installed flat tappet cams in roller blocks to save $$$
Old Mar 3, 2012 | 02:17 AM
racerx520's Avatar
thanks guys!
i already know its a roller cam, i wasnt sure if there were any subtleties that may have changed during the manufacturing of the tuned port motors that would relate to different cams other than flat tappet or roller.
next time i'm in the shed i'll have to look up the number on it!
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
