2 vacuum lines p/s of firewall?
Old Mar 10, 2012 | 11:36 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I have 2 vacuum line rear p/s of firewall i assum 1 is hvac and goes to plenum, but what is the other one?
Old Mar 10, 2012 | 01:23 PM
Guest
Guest
Posts: n/a
Re: 2 vacuum lines p/s of firewall?
cruise control.....did you even look.
Old Mar 10, 2012 | 05:25 PM
capj66's Avatar
Car: 1987 IROC
Axle/Gears: Borg Warner 9-Bolt Disc 2.77
I believe that it goes up to the heater control/bypass valve. It should be located up around the front of the valve cover on the passenger side.
Old Mar 13, 2012 | 06:54 AM
insomniac's Avatar
Engine: 5.7 L98
oh ok both the heater control valve and cruise i deleted so makes sense
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
TBRays98
Sep 6, 2015 05:05 PM
