need help with tpi Wiring
Old Mar 10, 2012 | 05:28 PM
camarodriver15's Avatar
i am doing a swap for someone the harness is from a 87 trans am. When the harness was pulled they pulled the engine control part of the harness with the computer. What i need help with is the harness is missing the part that where it plugs into the firewall and im wanting to know How the engine control part gets power to it i want to utilize his old harness and mate them together But i need to know where i need to supply power to the engine control harness any help would be very much appreciated
Old Mar 10, 2012 | 05:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need help with tpi Wiring
See diagram
http://www.chevythunder.com/198689_f...dy_1227165.htm
the under dash harness that has the computer plugs and the engine bay harness that goes to engine ;
both join at the firewall plug
Do you have both harnesses?
Old Mar 10, 2012 | 06:12 PM
Originally Posted by vetteoz
See diagram
i have the part i mentioned of the tpi harness and the harness from the car which is a 92 firebird 6 cyl.
Old Mar 11, 2012 | 08:50 PM
Okay What i really need to know is there is a 2 prong plug coming down by the battery What is it for? Im really familiar with the camaros harness But this is a lot different the plug has 2 10 or 12 gauge wires that are orange and black in color i know on a camaro the 2 wires that color are for the injectors and a fuse goes in it and then there is a red 1 prong wise that supplies power to the ecu. But this harness Dont have the single red wire does anyone on here know What the plug is for and where its suppose to plug?
Caspar
Jun 19, 2016 11:19 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
