corvette fuel rails in a z28
Old Mar 12, 2012 | 07:26 AM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
I've got a set of corvette fuel rails and I need to put them on a tpi engine in an 89 z28. trouble is the fuel lines coming in are on opposite sides. I need an adapter to run from the passenger side fuel rail fittings to the drivers side fuel lines. where can I get something like this and what size/ type fittings do I need. thanks
Old Mar 12, 2012 | 07:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: corvette fuel rails in a z28
Doubtfull you will unless you custom make something.
If you want to use stock hoses easier to get the F-Body TPI fuel rails
or do what most would do;
run new s/s braided lines from the fuel rails to hardline connectors on the frame as done with aftermarket intake installs
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
