1987 Firebird Formula TPI 350 stalling out.
Old Mar 13, 2012 | 01:14 PM
jimmy2s83's Avatar
Car: 1992 Pontiac Firebird
Engine: 454 BBC
Transmission: TH400
OK,
O2 sensor was cracked and ended up breaking on me. I could hear the exhaust leaking by it so I changed the O2 sensor. Now? I start the car and unless I throttle it the car stalls. Even cruising down the road if I let off the gas the car will stall out? Ran fine before this O2 issue. O2 sensor installed was identical to the one removed. When driving its fine just can't let off the gas.
Any suggestions?
Old Mar 13, 2012 | 01:43 PM
EagleMark's Avatar
Re: 1987 Firebird Formula TPI 350 stalling out.
Remove power from ECM to clear codes and try again...
Old Mar 15, 2012 | 12:08 PM
jimmy2s83's Avatar
Engine: 454 BBC
Transmission: TH400
Just wanted to update this post by saying that removing power to the ECM worked as you indicated.
THANKS!
jklein337
Sep 19, 2018 06:23 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
