Running Rich Wont Idle
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
91 L98 just swapped in running very rich at idle unless i hold the gas it will stall. upper rpm runs very lean.
New plugs, wires, msd distributor. injectors ohm out fine and when i test them with a noid light a couple of them seem to blink fast wait a seconf then start blinking fast again. But its a few of them that do the exact same thing... is that normal? Find it hard to believe multiple injectors would have the exact same failure pattern...
Where should I be looking? TPS is with in spec
