A computer controlled cam in my 305 tpi
Old Mar 22, 2012 | 09:09 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I have a 87 camaro it's 305 tpi. Original heads with 66,000 miles on them I want to get a computer controlled cam for it , one where I would need no tuning and one where I wouldn't have to touch my heads, I want to put this cam in and be done. Any suggestions guys?
Old Mar 22, 2012 | 04:30 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: A computer controlled cam in my 305 tpi
Anyone?
Old Mar 26, 2012 | 08:41 AM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
No such thing as computer controlled. There are computer compatible cams, which means easier tuning..
You won't get alot without a tune, but you might want to try a L98 or LT1 cam. Your MAF should be able to compensate for the increased airflow.
I would recommend datalogging after installation to make sure it is running correct. It IS worth the investment to tune the car..I've heard you can get 15-25 hp just by tuning a stock motor!
You should search the forums, as there are many members building up 305's.
Good LUCK!
Old Mar 26, 2012 | 06:18 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
Axle/Gears: 7.5 3.23 mini spooled
At the shop we recommend replacing the valve springs if going to a cam bigger then stock.As RS said no such thing as computer controlled cam.
BlueIroc-Z
Jun 9, 2019 03:22 AM
midge54
Jan 29, 2017 07:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
