What can I do to my stock TPI system
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
My stock 87 camaro lb9 305 has a stock TPI,what can I do to the intake runners and plenum that are on it now to get some more power, what is siamese mean when it comes to these how is this done, would love some help thanks.
Car: 1987 IROC
Axle/Gears: Borg Warner 9-Bolt Disc 2.77
Re: What can I do to my stock TPI system
Hi Quick, I to have an 87 IROC with a 305 TPI 700R4. This is what I did to mine and she is putting out about 230-235 horsepower. LT1 cam, Air Foil, Cleaned the ridges out of the front of the plenum, in the process of removing the dents out of the tubes opened them up slightly, K&N Filters, De-shrouded the injectors in the intake and polished, 1.52 Comp Cams roller tip rockers and new springs, Pace Setter Shorty headers, Dynomax high flow exhaust, removed the air pump system, removed the cat, heated o2 sensor.
In my opinion you do not have to go crazy porting and polishing the intake system for a 305 because it get more air than it can use in it's stock configuration, just clean it up some so the air flows smoother. Good luck and remember to have fun with it....Jim
Car: 1990 Camaro RS
Axle/Gears: Posi
So a cam from a350 lt1, heads have 66,000 miles on them think I'll be ok without springs?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1990 Camaro RS
Axle/Gears: Posi
alright so couple questions, with the lt1 cam can i use my timing chain and all that?
also,
With porting, is it an all or nothing thing, or could i port my plenum and runners and leave the base the same and see some kind of difference?
also,
Engine: 4++,350 & 305 CIs
Honestly, buy a bigger base and port it along with a better set of runners or switch to a steath ram.
You will maybe pickup a 10th maybe 2 at the track by porting the stock stuff.
Do some searching around on here and ask lots of questions to find out what your end goals are.
Car: 1990 Camaro RS
Axle/Gears: Posi
$750 for the high flo base and runners, even more for the stealth ram,if i get a little bit of a better improvement from the stock stuff then its better than nothing, just wondering if i neeed to port everything or if i just port my runners and plenum would i see something
Well port your stock plenum and base. Your looking at a 10th maybe, maybe 2 in the quarter.
The steath ram is fairly cheap. I think around 300$ maybe a bit more?? you just need the intake and fuel rails.
I'm not sure where the camaro guys get em cheap. Do a search on here or google.
I'm a firebird guy with a lower hoodline so I use mini rams.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
here u go...
http://www.summitracing.com/parts/WND-7540/
i would go with the stealth ram because the price is good.... just need to get fuel rails.....
Car: 1990 Camaro RS
Axle/Gears: Posi
Why can't I use my fuel rails with the stealth ram
Its a completely different design. Do some searching, researching and looking around at pix, you will see and read all you need to...
Car: 82 Z28
Transmission: T400
Car: 82 Z28
Transmission: T400
Car: 1990 Camaro RS
Axle/Gears: Posi
I read that the stealth ram makes too much air for a 305, and the car would be unstreetable. Is there any truth to this
Car: 1990 Camaro RS
Axle/Gears: Posi
after the summer im going 350 in the car, id like to put a stealth ram on my 305 now and then switch it when I put the 350 in. but I do not wanna lose torque in the street for now
Car: 82 Z28
Transmission: T400
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by quick90rs
I read that the stealth ram makes too much air for a 305, and the car would be unstreetable. Is there any truth to this.
Car: 1990 Camaro RS
Axle/Gears: Posi
Thanks, and the stealth ram would go on the 350 anyways,get itt now and not have to worrt about spending more this winter, just one question is can I use my factory prom with the stealth ram without tuning
Car: 82 Z28
Transmission: T400
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
The TPI was designed for the 305, and is the better match for your displacement. Curing the system of the inherent factory restrictions is your best budget solution for more power, whether switching to a more radical cam or just retaining your current one. Be aware that the size of your cam, and whether you are currently running the stock Mass Air or a later Speed Density setup is going to effect how the computer can compensate for the changes. As for your TPI, the runners should be port matched to the upper plenum and base at a minimum (or use your gaskets as a template and resize both), all transitions smoothed and any rough edging removed, the base smoothed internally of all the rough texture, and all dents removed from your runners. For a 305 the airfoil is not really any help, as stated by SLP in their testing (they don't recommend it's use for anything less than 355 cu in. as proven by dyno testing.) For a street car, the TPI system is a better match for you as it keeps your powerband lower in the RPM range. The Stealth Ram is designed for larger displacements, and much like the LT1/LT4 intake moves the powerband up into the RPM range, sacrificing a lot of low RPM torque for high RPM horsepower. While this trade off is desirable at the track, it isn't as beneficial on the street where you don't typically see high RPM conditions. The typical built street car simply isn't going to see 6000 RPM going stoplight to stoplight. A good example of this is the LT1-style 4.3 L L99 used in mid - late 90's full size cars, such as the Caprice. It used the LT1 intake on a smaller displacement, and had miserable performance.
As already stated, a good flowing exhaust with headers, the fewest restrictions possible, and a modern catalytic converter (it's a $25,000 Federal fine to remove a cat, but only about 1 hp loss for a modern one), K&N filters (or Fram Air Hog from Rock Auto, they're closeout and dirt cheap, and flow better than the K&N's). If you still have earlier perimeter bolt heads then roller rockers are an easy bolt on, and cheap. If you have the '87 up centerbolt heads, then there are few options available for roller rockers that will fit, and tall centerbolt valve covers are anything but cheap (I'm looking for some currently). Instead of the Stealth Ram, you might look into investing in a set of RHS Vortec heads instead. These are proven good for 30-40hp gains straight out of the box, are already machined for the lift of the LT4 Hot Cam, have thicker castings than factory Vortecs to resist cracking, and are drilled for both traditional and Vortec intake bolt patterns. Scoggin-Dickey and Edelbrock both make TPI Vortec base intakes also, with enlarged runners for more airflow and matched to Vortec heads. Combined with aftermarket runners and a ported upper plenum, these heads can feed upwards of 383 cu in without starvation. Keep in mind this setup is still intended for primarily street use, and not a dedicated street/strip car. The other benefit of Vortec heads however is a significant gain in efficiency, meaning a possible 2-4 mpg, as well as the power gains.
Another suggestion is to play with the Comp Cams online dyno at their website, Car Craft tested it with several of their previously real-world dyno tested engines and found it remarkably accurate, erring if anything on the conservative side. It only gives the option of Comp Cams camshafts, but if you use one close to your current or desired profile it will give you a ballpark reading of your build.
Car: 1991 Firebird
Engine: 383 stroker
... that is ridiculous, don't believe it. Air and fuel gives us our horsepower, and we control one to accommodate the other. Having too much air is a good thing, as this allows for more fuel to be injected and burned, thus giving you more horsepower. Now, having too little air, that would be a problem.
Originally Posted by Tom91Bird
Not really true at all. Power (mainly torque) comes from the velocity that the air is able to travel through the runners and past the vavles...
When you have a small displacement like a 305, it's hard for it to fill the volume of runners that are too large...
... at least until you reach an insane amount of RPMs. That's why you can see a power lose in the low RPM range.
Car: 1991 Firebird
Engine: 383 stroker
Once again, your speaking from the perspective of adding a better breathing intake manifold without bothering to change the tune. You simply cannot add more air without increasing the fueling, as the ECM has only enough O2 correction across the board, and that correction is roughly 6%. You can't run the engine lean then say to yourself "oh, the engine lost power because of the diameter of the new runners", that is just plain silly. I run a fully ported and siamesed TPI setup on my 305(s), which flows better than an HSR, and lost no power at all...[/QUOTE]
Actually again, you're wrong. I was talking about tuning the fuel properly after increasing the volume of the runners so drasticly. If you increase the runner volume too much for the displacement of the motor, you WILL lose intake charge velocity and vaccum and will lose low end power and torque. Why do you think that people don't just through in the largest cam that they can fit? Why do you think Nascars and drag cars turn such high RPMs. It's not because it's fun and sounds cool. It's because of the choice of parts that they use. They're heads, cams and intake have such large volumes that they have to spin those kinda revs to get the full power out of them.
And PS, your "modified" TPI setup does flow better then an HSR.
Actually again, you're wrong...
Your research is flawed Tom.
Car: 1991 Firebird
Engine: 383 stroker
You logic is noted. When you put on the biggest runner intake that you can find, and stab in the biggest cam that you can fit, give it your best tune and let me know how that works out for ya
Go back to sleep Tom, because your obviously in la la land. When you decide to wake up in the real world, you will understand that a single 1.84" intake valve is pulling air through a stock TPI runner with an individual diameter of 203.17 cfm (1625 cfm total), and/or an individual runner diameter for the Holley Stealth Ram of 275 cfm (2200 cfm total), THROUGH a 48mm throttle body which flows roughly 783 cfm.
Go back to sleep Tommy boy...
Car: 1991 Firebird
Engine: 383 stroker
"You logic"? Is that even English?
The argument. nothing more nothing less.
I have watched people bicker back and forth for years about this.
I know what works and what doesn't, been there done that.
I'm a "more/quality airflow guy" all the way, no matter what size the motor is.
I had a Stock longblock 305 running mid 13s with a ZZ2 cam, slp headers, runners cold air kit and other tricks. That car would of ran 12s with a non slipping trans. It would have flew with better heads and short runner intake if they were out back then.. Oh, stock untuned "350" chip running 24 lb inj. Would it have been faster with a tune? u bet.
I had a Stock longblock 305 running mid 13s with a ZZ2 cam, slp headers, runners cold air kit and other tricks. That car would of ran 12s with a non slipping trans. It would have flew with better heads and short runner intake if they were out back then.. Oh, stock untuned "350" chip running 24 lb inj. Would it have been faster with a tune? u bet...
And yes, that was a typo...
Car: 1991 Firebird
Engine: 383 stroker
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
